1 - 12 of 12 Posts
authorized corral.net advertisers
This Bracket from MMR allows you to mount the alternator to the location in which the A/C was originally located. Bracket allows for front mount Throttle Bodies etc. which would have normally been blocked by the large alternator.
*100% Billet Bracket Made in USA
*Hardware included
Order now: Alternator Relocation Bracket 4.6 2V 3V 4V Ford Modular [471100] - $79.99 : Modular Motorsports, Home of the Worlds Fastest Modular Engines
*THIS IS A BRACKET ONLY TO MOUNT THE ALTERNATOR IN PLACE OF THE A/C. BELTS, ROUTING, TENSIONERS AND ALTERNATOR WIRING WILL ALL BE LEFT TO THE END USER TO MODIFY, RELOCATE AND ROUTE AS SEEN FIT. MODIFICATIONS MAY BE REQUIRED.
Do you have any more pictures? Possibly of the backside so you can see clearance near the oil pan.
The product or alternator are not near the oil pan, are you trying to fit something between them?
It should be plenty far away
Would y’all hope to to have a pic of it installed with belt routed. I have the trickflow intake and don’t like how I have to flip the alt around so this would really help out.
Im sorry , we do not, belt routing is universal and there are many ways to do it with and without a tensioner.
So will this work for an 03 Cobra?
Sent from my SM-G928V using Tapatalk
Yes, but not with the factory timing cover.
Discussion Starter #12
1 - 12 of 12 Posts
