1 - 1 of 1 Posts
ok guys the car is almost done the goal is to fire it up on sun. after 8 months of rebuilding after it got stolen i think everything is coming together heres the mods currently
Engine: e7 heads ported milled .20"(not positive got em used cheap) 3/8 studs 1.6 roller rockers, TFS stage 1 cam, Ported upper and lower stock intake(yet again good deal) c&L 76 mm MAF, Mass air conversion, under drives
Exhaust: BBK 1 5/8 long tubes, 2 1/2 off road H, 2 chambers dumped
Driveline: 410, detroit locker, (no idea on clutch)
Suspension: subframes, front coil over drag rate, rear coil over drag rate, 90/10 front, 50/50 rear, no sway bar, upper & lower control arms
Misc 275,50,15 nitto DRs, NO AC, NO PS, electric fan, Carpet and sound junk removed, back seat removed, batt in trunk
its an 87 coupe btw
Is there anything that I am obviously missing guys?? Any guesses on ets? thanks alot for the help
1 - 1 of 1 Posts
