How do you setup strings to measure absolute toe?
I plan to use jack stands, fishing line, and a 1/32nd measuring device. I understand that the strings should be at the level of the center of the wheel and parallel to each other. But what reference points on the car do you use to get the strings exactly parallel with the chassis?
I just measure from the front and rear of the rear wheel rim. I've found a metal metric ruler to be the easiest to use.
