I have a 1991 Mustang GT and am trying to find the backup battery to the airbag module and can't seem to locate it.
The module has two part numbers:
FD0F14B056AA
"With Foam" F1Df14B056AA
Now my module has a strip of foam on it, so I'm assuming it's the "With Foam" number but I have no idea.
It unplugged from the harness with two plugs and was located behind the A/C controls. But for the life of me I can't find where a backup battery might exist.
Thanks for any help
it's the bank of capacitors inside the module, they are likely bad.
You can also blow the safety fuse inside the module if you disconnect a sensor with the battery connected.
No I'm looking for a separate box that is the backup battery. I thought it was behind the glovebox, but the only thing behind there is the A/C unit.
In the picture below the smaller box is what I'm looking for.
Well I found the backup battery. That apparently is good.
I got another module that was a different part number but supposed to be for 90-91 Mustangs and that gives me an error code of 13
Sigh.
