Air & Oil Separator tank or Valve cover Breather kit on a turbo. My frist turbo build and was windering what style would be better? 67mm turbo with 4.75 stroker
there is a lot of info on the topic but not a whole bunch of success stories that are consistent... I think it was (going totally off of memory here) that if you keep your pcv at the back of the intake or swap it out for a turbocoupe one then route an air oil separator to that.... meh... I really can't remember. It's very annoying is what it is and my car is not running so I can't tell you. I can tell you when I ran a breather it just misted the oil in my compartment and it sucked.... but some swear by them. Good luck.
I run a header evac kit. Constant vacuum on the crankcase, no vac pump to fail, no catch can to dump. Any oil vapors go right into the exhaust
