Here is my issue.
Note position of 90* inlet pipe that has to enter fender well but goes through small section of shock tower in my 65 fastback
The powerpipe is 4” dia and I’m thinking of cutting @5” hole and welding in section of 4.5-4.75 Id. Pipe and trimming it to fit the curve transaction between fender and shock tower
Just never seen that done and wondering if it should work of any other suggestions?
I would not cut into the shock tower
Can you not point it down?
Also where do you plan to mount the bypass?
Thanks Indy!
If I point the 90* down it runs right between the shock tower and exhaust header
If I point it straight back it runs just above all the header runners and would have to go through lower section of shock tower
Only option (I see) is to go through fender.
If I kept inlet pipe 3.5” it would just go through fender
But if I use my nice Anderson power pipe with 3.5”-4” 90* then the 4” pipe itself I’ll need to trim into shock tower a bit.
I think I might fit 5” tubing to fit to allow @1/2” motor movement
Will probably use insulating to keep aluminum powerpipe from rattling on the 5” pipe.
they sell 180 degree 4" silicone hoses... cut it just enough to clear the area you're trying to avoid
although also in that last pic it looks like you could take some height out of the hose at the blower end which would bring it forward more
Ok. Thanks to everyone’s ideas and help I got this done.
I ended up using rubber 3 1/2 to 4 inch 90° elbow connected to 4 inch cast aluminum 90° elbow then coupled that to my Pro M 92 right where the stock battery was located.
I had to lightly trim a hole in the fender apron and ended up covering trimmed edges with vacuum hose
Then I made a mount that bolts to my supercharger bracket that supports the mass air meter.
I’m happy with how it
1056856
1056857
came out.
