1 - 15 of 15 Posts
92 mustang, ex 4cyl car. Now has a 302 with blowthrough carb and turbo. My airbag light on the dash is constantly flashing. Is this just because there is no computer on board, or is this an indication of a problem with the airbag system.
IS THE AIR BAG module powered up?
What is the code?
I'll will double check power to the control module. Light blinks steadily 3-4 times per second, it never quits blinking.
retrieve the stored code
Aren't the codes stored in the computer?
No
Count the flashes
Module is seperate
5 flashes per second, key on, or running.
now tell me what that code means
Aren't they typically two digit codes? 5 flashes per second is fast is it not?
Both Primary Crash Sensors Disconnected, Assembly Plant Mode
Discussion Starter #12
Appearantly the crash sensors and harness were stripped when the engine and transmission were pulled. I'll try to find a used harness but most likely purchase new sensors.
Did you know they were missing?
Discussion Starter #14
Nope, if the airbag light hadn't been flashing I wouldn't have looked. I do feel silly for starting an electrical diagnosis thread when the culprit turned out to be major components missing.
1 - 15 of 15 Posts
