Gents, welcome
We all know about venting the tops of the fenders to release pressure build up/decrease front end lift. So i had another great idea (for now) instead of buying awesome vents and cutting and installing them, would taking a 3.5 inch router bit and drilling two or three holes over the tyre be a simple way to vent all the air up away from the wheels? And later on when and if i buy vents i can just cut a rectangle in and the holes will be a thing of the past.
Am im lost? Is this real life?
Gents, welcome
you must be cuttin some wicked track times to need to vent your fenders to squeeze the last 1/16th of a second out of it :wink2:
Lowes Racing sells fender louvers, they're in the HVAC section....but you'll get a much better result from venting the hood (if you haven't already).
hood is already done, so would drill holes not do the same thing as a vent for now?
If you can create a little bit of a lip in front of the opening to help direct air up and away that will help. You don't want air going back into the wheel well, but I can't see why some appropriately sized holes won't work.
