1 - 8 of 8 Posts
Who makes a good adjustable clutch cable kit and where is a good place to buy one from? I ordered one from UPR but it's back ordered for three weeks and I just found that out today... so I canceled my order and am looking for another one.
-Peter
I just have way too much play at the top of the clutch (about a 1/2 inch)... and also the cable seems a bit worn out... driving around for a long time on a hot day will cause the cable to stick...
So what and from where do you recommend buying?
-Peter
your stock cable is fine. Get a firewall adjuster and quadrant and your problems will be solved. But you don't believe me, it's cool. You will see :evil:
I believe you... but where do I buy one...
-Peter
I have a aftermarket clutch cable and it came with the quadrant made by outlaw, will the firewall adjuster work with all clutch cables?
96GT
00 Engine/Trans
I like the UPR firewall adjuster (I started out with the Steeda unit, but kept the quadrant in place and replaced the firewall adjuster). For the cable, if you have doubts about yours, get a replacement from Ford.
1 - 8 of 8 Posts
