I have an 86 5.0 and my AC relay, the one by the driver's side fender is toast - something's rattling inside it.
I tried to use 'the google' and I just can't find a relay that looks like this one - I even called the ford dealer who gave me the P/N - E2ZZ-19D-572A which doesn't look like it either. My connector plugs into this, not on the outside - and has the key slightly offset to the left - see pic.
Any help is appreciated,
Howard
Number they've given you is for an A/C clutch control relay. I'm seeing E6DZ-11433-A Motorcraft DY-484 for the WOT cutoff relay.
Try that on Google, see if it matches. Any ID numbers on the old relay?
cheers
Ed
Thanks for the reply Ed. I'm looking up those numbers now, but I can't see a good pic that shows the connector end. I sure can find a lot of relays that *don't* have the right key arrangement for the connector :)
any relay will work, just the base will be different
