just like the title says.. I have a 90 foxbody with h/c/i and I cant tune the damn thing because the computer is constantly seeing 150 degree engine temp. I know this is the default setting for a faulty coolant temp switch, but I have verified that the switch is not faulty with an ohm meter.
Any ideas?
its a 306 with 11r 190s, tf stage 2 cam, street heat intake, 30lb injectors, long tubes, egr delete.. tuning with a quarter horse. Had it running good when hooked to the quarter horse, burnt a chip and it runs rich and wont idle for crap.
The sensor is not a switch. It is a variable resistor called a "thermistor".
This is the sensor you should have. Note the resistance given in the text for various temperatures:
I would back probe the salt n pepper connectors . Possibly a broken wire somewhere.
