just installed new anderson power pipe and went out to play
a little on the boost guage saw over 12psi and let out of it ...
i have 3.33 pulley which was good for about 9psi to 10psi at
times.
should i worry about this new found power.
i knew there was going to be about 1psi boost but shoot 3psi easy, just on a mild power punch in 1st. gear(auto)
was running some very low 12.02 12.05 runs
where do you think it will be now?
high 11's ?
happy but worried about the engine now
:evil:
The same thing happened to me, almost.
I already had the powerpipe installed with my 3.60" pulley. (8psi) I gave the 3.33" pulley a try and boost was at 11psi before I knew it. I didn't feel comfortable with that and noticed a tiny bit of detonation so I drove back to the garage and put my 3.60" pulley back on.
I'm not ready for 11-12psi... maybe after I get the water injection installed. Did you notice any detonation? If not, you might be ok.
Rich
p.s. Go Bears.
