My fab guy is at a standstill until I tell him how I want this. 2 Options
Charge exits parallel to the top and then curves down
He'd use 2.5 inch pipe to make a lazy 90, and then head straight down where it would flare out to 4" for the Intercooler. Kind of like this.
And then transition into this.
Option 2 is to fire the exit down and then transition to the 4" IC piping. He's a little concerned with having the charge pipe run right next to the hot crossover. I will be having the hotside ceramic coated inside/out. You think the charge temps will be that affected by running within 2 inches of a hotside part for 2.5 inches? I just thing it would look cleaner firing down.
Any help is appreciated. Also need to gigure out how to fo from 2.5 inch to 4 inch on the turbo outlet.
Thanks for any help gang. The 4 valvle turbo Lightning from hell will hopefully roll soon.
IMHO, the extra bend will be more detrimental than being 2.5" away from the hotside. If your super concerned about it, fab up a heat shield or throw some header wrap on it and call it good.
i think if you heat wrap either the i.c pipe or the hot side pipe you should be fine .... my question is that a plastic valve cover??.. and how close is that to the hot side pipe it looks from the pic that it is real close......as for your i.c piping i would run it down instead of making that crazy 270 degree bend the more bends you make the worse.....but from the looks of the pics it looks great
i have a quick question for you ..what size turbo is that?
The close distance will not matter. My turbo discharge is about 2" off the crossover pipe and the air temps are ice cold.
Going to clock it down. Entire hotside will be ceramic coated. Turbo is Turbonetics T-76, Ceramic Ball Bearing, Q trim with a .96 A/R. The valve covers are metal. I painted them with 1500 degree ceramic paint. It's a built Navi 4V for my Lightning.
