How do you enrich the fuel with a dry kit? what happens exactly.
How does the wet kit work?
As I understand, the fuel pressure is constant on a returnless style fuel system. Will tapping into the fuel line for a wet kit hurt this or does the computer compensate?
I'm looking for as much detail as you can give me.
Thanks guys.
A dry kit taps into the vacuum and "tricks" the computer into dumping more fuel, at least this is what I've heard. A wet kit taps into the test port on the rails to draw fuel. As for fuel pressure, the computer wants it to stay constant (40psi I think). So it will on it's own raise the pressure to compensate for the fact that it is dropping. It doesn't hurt anything except for the feelings of the poor bastard you just beat.
