Hey guys. Just got a 98 cobra. Stock engine. Looking to put a set of better heads as well as a set of cams. Supercharger is in the
Plan as well. Please text me what you got. Ready to buy ASAP. 337-842-4555.
Forget heads and cams. Turbo after you put good rods and pistons in it and enjoy. 12 psi on pump gas is easy. Put you around 550hp. If you have your heart set on a supercharger, Kenne Bell and be done with it. Buckets of torque everywhere and a solid top end charge.
You seem be going straight for power. A head and cam swap may cost more $$ than you think on these cars. Said and done you would be at the same price of a used SC kit. ^^ So hes not wrong. But hes also talking Rods/Pistons. Get a used, or new SC kit. Slap it on and run 400-430 all day without needing to upgrade internals.
If you want a good improvement in the car.
Suspension: Full length SFCs from MM, coilovers( or good springs/koni yellows(but these either way)), better swaybars. -- Better Pads/rotors and braided brake lines. All
Maintanence: New FRPP Wires, new plugs(maybe after doing seafoam), fuel filter, Slightly better CAI but they dont do a whole lot for our cars, Shifter, better Pads/rotors and braided brake lines.
Power?: New rear gears and aluminum driveshaft (this is the best bang for buck for 4v cobras, and dont fear the gear!!), LTs, Tune
Do those things and each time you will love the car more and more.
Dont even think about U/D pulleys or Throttle Body. Not worth it on 4vs.
Sorry I dont have anything FS and maybe you know these things already. If so good luck!
