1 - 14 of 14 Posts
Round about, whats that normally in the 1/4??
Lets just say the car is set up for 1/4 mile and decides to run at an 1/8th track and turns almost 97mph:salute:
121-123 mph
So really a 96 mph pass would = around 119. And a 97mph would =120. I run 99 mph in 1/8th and go through the traps @ 123. This with a C-4.
it depends on alot...n/a? power adder? yadda yadda. i usually pull 27-28mph on the back half, 30-31 with the shot.
its at least high teens, maybe low 20's
mild street cars seem to go about 22 mph difference 1/8th to quarter imo
turbo's superchargers, differences in gearing make a huge difference.
Most likely around 120-122mph, but it could be faster or slower. The only sure way to find out is run it a full 1/4 mile. :)
I turned 97mph in the 1/8 cutting a 2.10 60ft and shifting from 1st to 3rd.....LOL!
Combo:
347
AOD
3.73 gear
67mm turbo
I've done it before when I had a quarter stick. From 1-2 you just pull the shifter, to get to third you need to squeeze the lever when pulling it. I had my hand on the lever and when I pulled it went all the way to third. I just aborted the pass after that though. I've never done it again, I always make it a point to just hold the shifter ball from 1-2, then I go to the lever.
Discussion Starter #13
LOL! Thats exactly what I did..........except for the letting out part:)
Well I figured the pass wouldn't be that good anyway and it was just a time trial.
1 - 14 of 14 Posts
