1 - 9 of 9 Posts
1996 Ford Mustang Mystic Cobra
#234
Complete 2004 Cobra Conversion (Engine, Trans, Interior, Wiring, Traction Control, Mach 1000 Stereo System)
Whipple 2.3L Supercharger
14lbs Boost 3.125 Pulley
540 rwhp on conservative tune
Metco Pulleys
JLT Ram Air intake
JLT Catch can Driver Side
JLT PCV Breather Passenger Side
Diablosport Mafia MAF extender
04 Cobra Fuel System with complete EVAP system
Dual Ford GT Pumps
60lbs Injectors
NGK TR6 Spark Plugs
Wrinkle Black Moroso Expansion Tank
Wrinkle Black Moroso Intercooler tank
Billet "Terminator" Coil Covers
"SVT" Oil Cap
Wrinkle Black Crossover
AFCO Dual Pass Heat Exchanger
Steeda Aluminum Radiator
Bassanni Off-Road X-Pipe
Borla Stinger Mufflers w/Turn downs
Complete 04 Cobra wiring from bumper to bumper
Upgraded Fuel Pump Driver Module (FPDM)
04 Cobra T56 Trans with 26 spline input shaft
MGW Shifter
Cobra Bob Shifter gasket
Spec Stage 2+ Clutch
AJE Conversion Cross-member
Hybrid U-Joint with Original )4 Cobra Driveshaft
Built Rear end (Straight Axle)
Moser 31 Spine Axles
Auburn Pro Diff w/Billet Stiffening Cover
Steeda 4 Bolt Caster/Camber Plates
Steeda Upper/Lower Control Arms
H&R Lowering Springs (Front Super Sport/Rear Sport)
Tokico D Front Struts
Tokico Blue Rear Shocks
Tubular K-Member
New 04 Cobra Control Arms
Subframe Connectors
New Slotted/Cross-drilled Rotors
Extended Wheel Studs
Cobra Calipers painted Red
17x9 Chrome Saleen wheels
04 Cobra traction and brake system
Black on Black 04 Cobra Front and rear seats
Complete Interior swap including dash
Duel Pillar Pod with Speed Hut Boost and AFR Gauges
20% Tint on all windows
MACH 1000 Stereo System
Cobra R Hood
Redline Hood Struts
Smoked Headlights
Saleen S281 Spoiler
Export Mirrors color matched to Mystic
Sequential Tail Lights
John Smith Racing Wiper Delete
Grand Design Mat Cobra Trunk Lid Mat
New Cobra and SVT Exterior Emblems
Lethal Performance Fog Light Black Out Covers
UPR 14in Antenna
New Ford Headlight Switch
Runs Great, I would drive it across the county without hesitation
Huge Folder of Receipts and paperwork to document the build/swap
Swap was completed when chassis had 40k miles and 04 Cobra donor car had 42k, odometer showing 49,266 miles which is on the drivetrain, so chassis is 2k miles less than odometer reading.
No Trades
$22,000 obo
Quick video of a cold start
1 - 9 of 9 Posts
