1 - 8 of 8 Posts
Parted out 96 cobra engine, ported heads, Cloyes Hex a just gears and timing set, texsid Block, has 6 bolt crank no issues
Texsid Blocks 350.00 have 2 here ...
also have 2 WAP blocks 250.00 each
6 bolt cast Crank 100.00
8 bolt cast crank 125.00
Ported B Heads and cams 500.00 a set
stock B heads and cams 250.00 a set
Timing cover with tensioner and idler 100.00
COP valve covers 100.00
T stat housing and hoses 80.00
Heater core hoses 35.00 each
Cobra intake 350.00
Accufab Throttle Body 225.00
Oil pan 35.00
Oil cooler 125.00
IMRC deletes 60.00
Alternator 40.00
Alt bracket 25.00
Coolant crossover 75.00
24lb injectors 75.00
Fuel rail 75.00’exhaust manifolds 80.00
Msd wires 40.00
Energy suspension engine mounts 75.00
6 bolt flywheel almost new 40.00
Clutch almost new 40.00
Starter 30.00
T45 trans harness 40.00
99-01 Cobra Intake 350.00
03-04 Mach1 intake 275.00
more here in bins, accessories, pulleys, timing covers, valve covers, B heads.. tensioners, hoses, you name it I may have it...
Tons of parts here just ask..will ship
Pm me price on alt & poly motor mounts to 85286 please?
Sent from my VS996 using Tapatalk
1 - 8 of 8 Posts
