For sale is my Rio red 96 mustang that was built to look like a 95 cobra this car has 4k mile since the ground up build that has taken place
The mustang started life as a white v6 car and has been disassembled completely. A complete custom 12 point cage was built in the car
Then the car was sent to the power coaters to have the cage coated gloss black. After that was done the entire car was painted Rio Red piece by piee to insure the bet job possible here is a list of all of the goodies that are on it
Engine
352ci
A4 Block .060 over
Sony Bryant crank
Carrillo rods
CP pistons
Plasma-moly total seal rings
SVO aluminum heads
Roller rockers
Hardened push rods
Main girdle
Head and main studs
Clotes True double roller timing chain
95 cobra intake
95 cobra injectors
Transmission
Viper spec T-56
Spec stage 3 clutch
Drive shaft loop
Pro 5.0 shifter
Custom drive shaft
Custom trans cooler
Weldon pump and custom -12 lines
Brakes
95 cobra front spindles
Brembo 6 piston front calipers
Stainless steel brake lines
Cross drilled and slotted front Brembo rotors
Cross drilled and slotted rear Brembo cobra rotors
Brembo rear calipers
Brake controller
Rear End
95 cobra 8.8
Kenny brown custom built rear end
Kenny brown 31 spline Axles
Kenny brown 4;56 REAR GEARS
Custom rear diff cooler
Custom rear diff cover for the cooler made by Kenny brown
Fuel system
All new 95 cobra
Fuel safe with 255 in-tank pumps
Interior
Cobra white face gauges
Black on black interior all new
Custom black leather Recaro seats
Custom 12 point cage all powder coated
Cobra air bags
03 cobra T56 shifter knob
All cobra interior in leather
Every piece of interior was replaces with all new stuff from ford
All 95 cobra black
Halon fire system
Suspension
All Kenny brown I mean every thing they sold is on this car
g- load
matrix sub frame conectors
pan hard bar
(stock k member from a 95 cobra Kenny brown didn’t make one when this car was built)
Lowered with Kenny brown springs
Kenny brown caster camber plates
Kenny brown bum steer kit
Kenny Brown custom front struts
Kenny brown rear shocks
Body up-grades
Factory ford 95 cobra every thing
Nose
Wing
Trunk
Rear bumper
Front bumper
95 cobra head lights
95 cobra tail lights
All the wiring
Custom carbon fiber side scoops fully functional to cool trans and differential
Vis carbon fiber cowl hood
Wheels
OEM Chrome cobra wheels
2 17X10 chrome cobra wheels
New nitto 315X35X17
Nitto 275X40X17 front tires
This car was Done to look like a 95 cobra it runs and drives perfect with no issues I have owned this car for the last 10 years. It has been a ground up resto to a perfect road race car and I have only driven it about 4k miles since the car was done. This thing handles like no tomorrow. It is registered and insured and street legal, Please under stand this is not a ¼ mile car it was purposely built for road racing the hood is still carbon fiber color and so are the side scoops. The car is a “new” car well sort of .. I will consider trades plus cash I have well over 70K invested in this car. Now that the car is done it is time for a new project
For looking
Please pm me info on any trades i dont plan on posting pics however I will send them to who ever has something im interested in
thanks
I know I know
:worthless
Dan, I have interest in your this car and also your 03 Mach 1. Your PM inbox appears to be full so couldnt send you a message. Once you get it cleared ill send you the questions i have for you about both of your cars. Thanks
-Patrick
-Patrick
Done
