1 - 1 of 1 Posts
I just put new head gaskets on my 95 mustang.......
It started right up when I was done so I shut it off. But then it wont start again???
I dont know why it turns over fine but it sounds like the timing is off because from what I can hear its firing when the exaust is open.
Would it have started right up the first time if the timing was off is there something I should check before I start messing with the timing???
I did have the distributor off I pulled it out when I was working on the car but I think I put it back down in the teeth in the right spot...
IF YOU THINK THAT IT IS THE TIMING THEN HOW AND WHAT DO I SET THE TIMING AT?????
any help it appreciated thanks
J0SH!!!
1 - 1 of 1 Posts
