Im in the process of putting on a cartech street sleep kit on my 94 mustang gt. If I am correct the kit is setup for a draw through MAF. My question is can I change that to a slot style blow through and mount in on the pipe going to the throttle body about 12 inches infront of it. I know you need the straightest pipe possible. Was just wondering if this would work for me, I'm looking at getting a PAS extreme. Also was wondering if my 61mm precision turbo is too small for my 302. Only planning on running 10-12lbs and making between 400-450.
Yes you can convert it to a slot maf. You just need the meter and the wiring harness. poweraddersolutions.com would be who I would get that from. You'll also need the flange that the meter mounts to. PAS sells that as well, although I think racepartssolutions.com has the flange a little cheaper.
Your 61mm turbo should be find for the power that you want to make.
