As the title states, where do you all have your ignition control modules mounted? I would like to keep from cutting up the inner fender if at all possible.
Thanks for the reply. I knew that it needed to be moved to the inner fender but i cant seem to find a good place where its not in the way or to far away from the harness. Any pics would be greatly appreciated.
I moved all the wiring inside the fender. My module is attached to the frame rail with zip ties using pre existing holes. Didn't have to extend any wires. I'll try and get a pic this weekend
Sent from my Inspire 4G using Tapatalk 2
I cut and extended my wires about 6" and bolted it to the frame rail.
Thanks for the replies. I ended up drilling and tapping the frame rail and mounting it there.
