1 - 10 of 10 Posts
I know this question has been asked 100+ times but What is the most common size tire to run on the back of a fox gt? I'm not sure if a 27 will clear the ground effects, so i'm looking at 26's I'm currently running a G60-15 racemaster on draglites that are shot and need new tires by this friday if i wanna run this year. Kinda hard to decipher the letter code on the M&H's. The only reason i ask is i think my wheel offset is too shallow, aka the tires stick out a little bit, but i have adjustable lowers so i can raise the ride height to clear if i need to. Looking at QT pro's and MT ET streets as the local cops are kinda jerks about full slicks. Thanks
I ran 26X8.5 ET Drags on my old 91 GT. 1.58 short times.
i run 28x9 et drags on mine but it does rub the skirts a little at the track but no biggie.
Depending on how fast your car is and what you want, i would run either a 26x10.5 ET street or a 26x11.5 et street.
The 10.5 et street is sized close to a 26x8.5 et drag and the 11.5 et street is sized close to a 26x10.5 et drag
Mickey Thompson does not offer a 26 X 10.5 ET Drag. They offer 26 X 8.5 and 26 X 10's
The 26 X 10 ET Drag(Stiff sidewall) has a 9.8" tread width.
The 26 X 11.5 ET Street has a tread width of the same 9.8"
The 26 X 10 ET Drag is much softer and will hook much harder.
I went from 1.60 best short time on 10.5 ET Streets, to a 1.47 on 26 X 10 ET Drags. No other changes.
what size rim is it? what backspacing is the rim? if its a 15 x 8 then go with a 26 x 10.5 et street if its a 15 x 10 with 6.5 bs then use a 26 x 10.5 or 27 x 10.5 et street. If you dont mind rolling the fenders and beating the holy crap out of your inner fender you can slide a 26 x 11.5 et street in there with a 6.5" bs rim.
It really depends on how you've geared the car and how good your suspension is. A 26x8.5 ET Drag, or 26x10.5 ET Street on a 15x8 wheel will be plenty of tire if the car is geared a little lower.
I beat the hell out of my car and did some quarter panel lip cutting to make my 28s fit.
With my old buzzard motor I did 1.58 sixtys with 26 x 10 MT Et drags.
How fast you wanna go?
Look at what the NMRA P/S cars do with 26 inch tall tires.
1 - 10 of 10 Posts
