1 - 13 of 13 Posts
Just wondering if this compression is to high in my 302? Car is boosted. What's the highest boost level can I go?
Sent from my Droid using Tapatalk
Jersey True Street Guy
More compression makes more power. Like the guys said, watch it with pump gas...
My motor gave us a big smiley face when we gave it more compression...
If running race gas you can go higher then 9.25 safely. The things some of the 275 owners do with motors scares me....
i run 9.5:1 with iron heads, 12#'s and pump gas. no problems so far.
old motor was 9.8-1 with #15 lbs of boost on 93 made 567rwhp
new motor is 8.5-1 with #30 lbs of boost on E85. no idea find out friday for hp
if you have a good tuner youll be fine. make sure you have good fuel pump/pumps
1 - 13 of 13 Posts
