i have a 1987 gt, did alot of work so far. windows rolled down for a while then was having issues. I tested motors and they work, replaced the switches and now windows will not work. i checked the fuse box and nothing. any clue what am missing?
sounds like you checked everything except the wiring
you are losing voltage somewhere in the circuit
figured it out, the window motors where stuck between gears. i removed them, greased them and good to go. thanks guys
