Black 86, 10 pt cage, mini tubed, rear shortened, removable rear bulk head, rear adjustable coil overs, trz upper rear arms and arb, BBRC offset lower arms, 8.8 with 33 spline axles, 9" ends, spool, rear girdle, 3.55 gears, subframe connectors inside and out, has team z kmember with motor mounts, also set up for motorplate. QA1 front struts with coil overs, racecraft short adjustable front a-arms, manual rack and shaft. Car is wired but needs to be redone. 15x12 rear wheels with 325/50/15 big drag radials, 15x 3 in front wheels are track stars.
Engine is RGR 363, Motorsport r-block, internal balanced eagle internals, Mahle pistons, RGR blower spec cam, Z heads, shaft rockers, ati balancer set up for crank trigger, moroso pan, ported lower system max intake, upper systemax was double extrude honed, Motorsport 1 3/4 shorty headers,full flowmaster 3" exhaust system, Mls head gaskets and head studded. 2 core aluminum rad with dual fans.
Freddy Brown manual valve body AODE with brake, 3k stall converter, with hurst pistol grip shifter
Big stuff 3 base system with dai, mad distributer set up for cam sync, innovators west crank trigger mount, and 83lb injectors, full BBRC fuel system with sumped tank with internal mounted manga fuel 750 pump, fuel rails, filter, lines, y-block and regulator. Also mad digital 6 with coil
Leash electronics sportsman board, and street car board for turn signal and etc, twin 70 amp relay board for fuel pump and intercooler pump
Vortech t-trim, complete with mondo discharge tube and bov, power pipe, dual mounting bracket for passenger side, 8 rib pull lies 8" renegade pulley with full kurgan brace.
Baer racing ss+4 front and rear disc brakes, front spindles and bearings from sn95 car. Manual master with max Motorsport adjustable pedal
Plus much more
Car has been sitting for years, motor and trans 1 year old. Everything new except injectors, coil and blower. Needs to be assembled. 95% there need drive shaft and misc. will post pics later. Car could use paint
SOLD
PM with questions or interested in seeing. Vehicle in Chicago area.
Still for sale, just got it out of storage. Will try and get pics later this week, or pm me if in the Chicago area and want to see it. Thanks Bob
