Hey guys I've got an 86 coupe I'm going to be putting an LQ9 into but I have a couple of questions. I already have the motor and I bought the coupe with a 4.6 K-member already in it. I understand this K-member can be used without too much trouble, however what kind of headers are you guys running with this k-member? What clears and what doesn't? Does anyone know?
Also does anyone know if using a 4.6 k-member with stock 4.6 motor mounts will allow the LQ9 with the trunk intake to fit under the stock fox body hood?
Appreciate the help, thanks!
the intake will not fit under the stock hood. you will need to swap it for an ls1 ls6 manifold.
Dimitri all you have to do is text me. Truck intake wont clear stock hood. Dynatechs for the swap should fit. If your using 4.6 kmember what steering shaft are you using? Thats going to be the only factor really that I can think of.
