OK EVERYONE I HAVE DECIDED TO SELL MY BABY I GOT A 86 MUSTANG COUPE AND THE MODS ARE AS FOLLOWS:
ENGINE:
406 CI SBC
5.7 RODS
.30 TRW DOMES 12.5 COMP.
PORTED BOWTIE HEADS 2.02 1.60 VALVES
SUPER VICTOR INTAKE MATCH PORTED
LUNATI .640 LIFT SOLID FLAT TAPPET CAM
CLOYES HEX ADJUST TIMING SET
MOROSO OIL PAN AND PICK UP
MOROSO ELECTRIC WATER PUMP
1.5 ROLLER ROCKER
MOROSO VALVE COVERS
TRANS:
FRESH 2 SPEED POWER GLIDE
1.76 FIRST GEAR
TCI TRANS BRAKE
TCI DEEP ALUMINUM PAN
PTC 5500 STALL WITH TITANIUM SPRAG
REAREND
4.88 GEARS WITH SPOOL
IGNITION
MSD 7AL2
MSD PRO BILLET DISTRIBUTOR
MSD BLASTER 2 COIL
MSD WIRES
SUSPENSION
EIBACH FRONT SPRINGS
LAKEWOOD 90/10 STRUTS
50/50 REAR SHOCKS
5 LUG CONVERSION
WELD RODLITE WHEELS 3.5 AND 8'S WITH NEW FRONT TIRES AND REAL GOOD 28X10.5 ET DRAGS
OTHER STUFF
DEDENBEAR CROSSOVER DELAY BOX
ALL MSD RPM MODULES FOR AIR SHIFTER AND TWO STEP STUFF
HURST QUARTER STICK SHIFTER
RACING SEATS
5 POINT HARNESS
8 POINT CAGE
8 INCH COWL HOOD
X PIPE WITH 1 CHAMBER FLOWS
8 GALLON FUEL CELL
TWO FUEL SYSTEMS
ONE MALLORY COMP 140 PUMP
ONE HOLLEY BLUE
950 CFM HOLLEY CARB
CAR IS STREET LEAGAL ALL HEADLIGHTS AND TURN SIGNAL AND WIPERS WORK THE LAST TIME I GOT IT OUT IT WENT A 6.69 ON THE MOTOR SPINNING THE HIT OF THE GAS NEVER GOT TO USE TRANS BRAKE I DROVE IT THERE AND DROVE IT HOME ASKING $15,000 OBO 423 421 9399 FOR MORE INFO I HAVE PICTURES BUT CANT POST THEM BUT CAN EMAIL THEM THANKS FOR LOOKING
what will you take for it without all the bowtie stuff? Not really interested in all that junk, but the rest of the car sounds like a quality piece.
