1 - 10 of 10 Posts
1986 mustang LX coupe car ran 6.00 1/8 mile and 9.50 1/4 mile @ 140mph with 1.29 60'shifting @ 7000
on a 9" tire with 175hp nitrous on 24 degrees total timing. Good clean Ky title this car has been
tagged and insured since I have had it. This is a original v8 5-speed car ex florida highway patrol car.
Know for some details
ENGINE
331 stroker,probe pistons, h-beam rods, steal crank 0 Balance 8.5 compression mexican block,
canton 7gt. oil pan, canton main girdle, lunati custom grind solid roller cam, lunati lifters,
lunati lifters,csi water pump, trickflow twisted wedge stage 3 ported Heads by Brian Tooley,
1.6 scorpion roller rockers, sheet metal valvecovers,Victor Jr. intake stage 3 ported by fox lake,
Barry Grant 850 carb.,0 balance dampner,
TRANSMISSION
Dynamic mighty might c-4 transmission with reverse manual valve body, with transbrake,
deep aluminum pan fully rollerized transmission, JW bellhousing, 0 balance JW ultra light flywheel,
FMS Aluminum driveshaft, Quarter stick shifter
REAREND
8.8 33 spline moser axles, C-clip eliminators, 33 spline moser spool, FMS 4.10 gear,
Aerospace 4 piston brakes with slotted and drilled rotors
SUSPENSION
QA-1 K-member, QA-1 A-arms, upr coilover kit, QA-1 12 way adjustiable struts,QA-1 caster camber plates,
Flaming River Quick ratio manual rack, Flaming river steering shaft, supframe connectors, Lakewood 50/50 shocks,
Anti-roll Bar, South side lower control arms, double adjustable upper control arms,
WHEELS & TIRES
Weld draglites 15x3.5 FRONT WITH 165R 15 TIRES, 15X9 on back 5.5 backspacing with M.T 29.5x9 slicks,
Ignition
Msd 7al-2 box, MSD window switch, MSD billet distributor
COOLING
FMS 3 core radiator, summit catch can, 2 elctric fans, CSI elctric water pump,
MOTOR fUEL SYSTEM
5 Gallon RCI fuel cell in trunk, Holley blue pump, # 10 Russell Stainless Steel Braided Lines,
Russell Fittings
NITROUS FUEL SYSTEM
1 Gallon RCI fuel cell under hood, Holley blue pump # 8 Russell Stainless steel Braided lines,
Russell Fittings
INTERIOR
Black inter, 2 RCI race seats with slides, 10 point roll cage, ARC switch panel roll bar mount,
Rear Fire wall, Simpson window net, Simpson 5 point harness Quick release,
AUTOMETER SPORT COMP GAUGES
Motor fuel pressure gauge, Nitrous fuel pressure gauge, Water Temp. gauge, Oil pressure gauage,
Nitrous pressure gauge, 5" Tach with shift Light
NITROUS SYSTEM
NOS double cross plate wet nitrous kit adjustable, NOS purge kit
I know I have forgot some stuff e-mail [email protected] or call 502-859-3945 if you have any ?'s
I built this car from the ground up. all parts was bought NEW the car has 16 1/4 mile passes on it.
18,500 O.B.O might be interested in trades just let me know what you have.
PLEASE SERIOUS BUYERS ONLY
will sell complete motor and transmission exhaust everything for $10,000 or rolling chass. for $8500.00
pictures sent if you need pictures of something else let me know thanks I will get more if you need them
the pics i got were small can you get more ,let me know thanks.
more pictures sent thanks
ttt open to trades just let me know what you have
1 - 10 of 10 Posts
