not sure if i can post this in here or not since i changed the look. rust free az car. located in phoenix az
86 mustang for sale
I have a 86 ford mustang that has been converted to the 87-93 look.this what is done to it
engine
Stock block with 331 stroker 336 rwhp on motor 468 rwhp on 150 shot on nitrous
Eldelbrock performer heads
Dss main support
Comp rockers
Comp cam
Trick flow r intake
90mm pro products throttle body
80mm c&l mass air flow sensor
Manual steering rack
power steering, ac was taken off because the stopped working.
mark viii fan
Aluminium radiator
undredrive crank pulley
Breather tank with an fittings
Ford Motorsport valve covers with an fitting to breather tank
Nx nitrous kit w/ plate. 50, 75, 150,200
2 nx bottles. 1 full 1 has about 8 lbs
Anderson power pipe
3G alternator
Water pump and battery are new
Mallory 586 ignition box
Dynatec 1 7/8 to 1 3/4 to 3inch collectors
Dr gas 3 inch x pipe
Spintec pro dumps 3 inch
Aeromotive bypass regulator
Push lock 8an pressure and 6 an return
Magnafuel 525 pump
Sumped factory gas tank
power train
C4 to and 800hp
Needs converter
Trans cooler with fan
B&m hammer shifter
Aluminum drive shaft
3.73 gears all new bearings in the rear end
Jegs line lock
Manual breaks
4 wheel Disc brakes
31 spline axles
Long arp studs
exterior
89 front bumper and new head lights
2.5 inch steel cowl hood
limo tint all the way around
interior
88 dash and center council
90 140mph speedo
air fuel ratio guage aem wide band
water temp guage summit electric
oil pressure guage auto meter carbon fiber mechanical
Trans temp guage electric
86 gt seats
6 point bar w/ swing outs
Simpson 5 point harness bought in feb
Battery in the rear
Kill switch
suspension
front
qa1 tubular k member
upr lower a arm
upr coil over kit 12-150
Convro pros 3.5 x15 (centers painted black)
Vw tires
rear
Jegster upper controll arms
Ump lift bars lower controll arms
Saphical bushings
Convro pro 8x15 (centers painted black)
Mickey thompson drag radials 255/60xr15
Stock rear springs
the goods about the car
Very fast
the bads
Car is in primer black.
Cowl hood flew open and bent hood
No ac or heater
Needs converter for trans.
Best et 10.25 @134 on 150 shot with a 5 speed
7000
thanks robby
