1 - 11 of 11 Posts
I purchased this 1986 Mustang GT in September 2012 from a gentlemen in Kansas City which owned the car since 2006. The was car then shipped to Miami, Fl where it's been living in my garage since. I was planning finished her, and make her a full time auto X and road race car while still looking like a real clean 86 GT. However, due to my work schedule and my current assignment this project has been delayed numerous times.
According to the previous owner, the paint is partially original. I would rate it as seven due to vehicle age, paint flaws and small chips when the previous owner road raced it. I know the front mask and hood was repainted. The car is extremely straight and has never been crash or has any signs of rust or repairs. It does have a same dent between on the driver's side door. (between molding/lower half). I would have to show it to you person. The interior is 8 and very clean for his age. I have way over $16k into it, thats including the purchase of the car. But the car clearly has over 16K in parts and labor alone.
1986 Black Ford Mustang GT -VIN# 1FABP28M8GF240160 / 33,xxx miles original miles on the body. Only options the car came with was sunroof, rear defrost and A/C. I have the Original window sticker, build sheet and a 3 inch binders with all part & labor receipts.
Since I've owned this car, all repairs and upgrades have been done by LUJAN MOTORSPORTS home of the first 7 second NMRA True Street Stang.
NOTE:
I've only driven the car approximately 600 miles since I've owned it. Last year I drove up to PBIR and ran a [email protected] with 1.82 60ft. This was with 17 inch M/T 275 drag radials,550 lbs front rate springs and monroe GP shocks. Unfortunately I had a 5700 pill limiter and my clutch was properly adjusted. I'm sure she's capable of running somewhere in the 12.00's on motor maybe even high 10's on spray. Only raced her once unfortunately :(
The week before going to the track, she made 387 rhwp on 93 pump gas. Due to a couple of changes she might be at 392 rwhp now.
NEEDS:
The fuel gauge does not read accurate (off 1/4), because the Auto Meter Fuel Gauge ohms does not match the sending unit. The A/C is blowing a little warm it needs to be recharged. If you are planning to street drive this car a lot, I would re-align the car for street specs so you don't wear out the front tires.
MODIFICATIONS
Cervini 2.5" Cowl Induction hood
SVO Mustang Side sails
ENGINE
'69 351w block (std bore)
'69 351w crank std
Clevite 77 main bearings
Clevite 77 rod bearings
Clevite 77 cam bearings
Felpro gasket kit
Felpro 1011-2 head gaskets
Edelbrock Victor JR cylinder heads, 2.05" intake, 1.60" exhaust
Edelbrock Victor Jr Intake ported to match heads & balanced flow
-10 Fuel lines and -8 lines
Paxton fuel pickup
Holley Electric fuel pump
UPR high volume inline fuel filter
K&N 14" x 3" with a Moroso High-flow base
K&N Extreme 14" filter lid
Comp Cams Magnum 292H camshaft
FMS steel double roller timing set
Comp Cams Pro Magnum rockers (1.6:1)
Comp Cams Hardened alloy pushrods
Comp Cams hydraulic lifters
Summit Racing cam thrust bearing kit
Melling oil pump FMS windage tray
Ford Motorsports oil pump drive shaft
Canton 7 qt oil pan with baffles and scrapers
Ford Motorsports damper (SFI rated)
Ford Motorsports Billet Steel flywheel (SFI rated)
McCleod Scatter Shield setup
ARP head studs
ARP fastener kit (all around)
MSD 6AL ignition module
MSD billet distributor
MSD Blaster II coil
Ford Motorsport 9mm wires
Ford Motorsport Black Valve covers
ZOOM Kevlar clutch disc and pressure plate Ford motorsports fuel pump block-off plate
Edelbrock Victor water pump
EXHAUST
BBK 1 3/4 long tube headers (modified 3" collector)
Custom 3" X pipe
Magna-flow "straight-thru" 3" race mufflers
CHASSIS/SUSPENSION
Global West Sub Frame Connectors
Global West SFC Supplemental Reinforcement Kit
Global West Drive Shaft Safety Loop
Griggs Racing front coil-over kit (GR-40)
Griggs Blue coil 550lb/in front coil-over springs (replaced & purchased new one 450lbs)
Griggs Blue coil 350lb/in rear coil springs
Maximum Motorsport caster/camber plates
UPR aluminum rear lower control arms
Griggs Bump Steer Kit
Griggs Severe duty torque arm (GR-40)
Griggs Severe duty pan-hard arm (GR-40)
Griggs Tubular K member (GR-40)
Griggs Tubular A arm kit (GR-40)
MONROE GP Rear Shocks
MISC. OTHERS
FMS mini-starter
Moroso rear battery mount kit w/cutoff switch
Full Autometer Phantom Gauge set
Tremec 3550 5 speed manual transmission
Pro-5.0 Tremec shifter
3.73 FMS rear gears
FMS 31 spline tracloc rear differential
SVO 8.8 rear girdle with APR stud kit
Griffin alum racing radiator w/oil cooler
31 spline Moser race hardened axles w/3" studs ( Brand New 100 miles)
Flaming River manual 18:1 steering rack & steering shaft
200 amp Beavco modified 3G
MY UPGRADES:
NEW 4 BBS RX SILVER 17X9 WHEELS
NITTO 555 Rear 275/45/17 tires $350
Pro system carb $725
Edelbrock 1 inch spacer $30
Steeda strut tower $125
MSD black cap & rotor $25
Chrome coil cover $15
Trim paint. $75.
Floor mats $75
Ford door sill emblem $10
Window run channels $60
Parking brake boot $12
Cowl grill $55
Driver side weather strip $16
New Antena $15
Hood Secure Latches/Installation $200
Rear fender lip roll $85
Steeda Oil Cooler & Filter adapter $170
Omega Alarm GPS Tracking System $300.
Engine Bay elec. wiring clean up $500
ENERGY Poly urethane motor & trans mounts $169
Lockar throttle cable $99
Billet carb linkage $120
Black AN fittings & carb fuel lines $190
Spark plugs/Oii change/Dyno tune $500
Pioneer CD/Bluetooth Radio, Slim Amp (installed under passenger the seat) , Pioneer front and Rear Speakers $725
OEM replacement wipers $40
Lujan 3000 cfm Electric Fan $290
UPR chrome radiator hold down $45
95 Mustang Front Spindles $175.
5 lug conversion with 2003 cobra front & rear calipers $650
Power Slot front and rear rotors $350
Northcar rear brakes calipers brackets and emergency brake cables $195
Maximum Motorsports Stainless steel front & rear brakes lines $180
Maximum Motorsports rear axle brakes lines $200
Wilwood rear brake Prop valve $55
93 Mustang cobra master brake booster installed $250
3M window tints $120
Alignment by APEX $85
LMR Lug Nuts $50
LMR Door sills $74
LMR Door handle Bezels $30
LMR Inner Front Seat Belt sleeves $38
NEW Charcoal Gray Headliner $180
KONI Yellows Single Adjustable for Coil overs $800
GRIGGS 450lbs Coilover front springs $175
Interstate Battery $95
Holley fuel pump $150
Fuel Regulator & Gauge (Relocation of the Fuel Lines $200)
Fuel Filters $25
Starter Solonoid $25
Starter Heat Shield Wrap $20
The only trade I would consider is for a 99-04 Lightning or 03/04 Harley F150. I do not need to sell the car, I just hate seeing this type of car just sitting there.
I'll let her go for $10k Firm
I work a crazy hours with no set schedule so just give me a little time to respond.In my opinion, won't find a cleaner four eye with all these mods for this price anywhere. I would really recommend for you come and see this car in person. For more information or pictures please call or text me ar 786.299.1030 or [email protected]
Jim's is the orignal builder of the car. His friend Mike purchased the car years later and I purchased in 09/12. Jim did a great job a documenting the build.
Jim's Stang!
I bought this 86 in April of 2006 from Jim. Hector bought it from me sight unseen. Hated to sell. Jim is a good friend and did a fantastic job in building her. The buyer of this Mustang will not be disappointed. The EFI was ditched back in the early 90's from the person who owned it before Jim. Car has run a best of 11.8 @116 with slicks and skinnies. Love the 5 lug swap. Something Jim and I didn't get around to do. GLWS Hec. Hope she goes to a good home. I have a few vids of her on youtube. I had no idea this was the last cruise Angie and I took in her.
https://www.youtube.com/watch?v=D1bwyP_VKwM
1 - 11 of 11 Posts
