86 GT turbo L.S
Bought a new race car and this one's up for sale.
1986 Gt. ORIGINAL BODY AND PAINT car with no rust top to bottom. I am the 3rd owner from new and comes with clean title.Car is extremely well built.Has tubular front K with Koni adj drag struts and coil over conversion.tied frame and reinforced torque boxes and drives haft loop.asj rear upper and lower control arms attached to a braced 9"rear end with nodular case,spool and big strange axles and will wood rear disc brake set up. Engine is a stock 5.3 LS with re gapped rings and fresh gaskets. home fabbed hot side utilizing stock manifolds. Turbo is a Precision turbo 70m with a .96 hot side. quick fuel blow thru carb . Fuel system is consists of a sumped stock tank with aero motive a1000 fuel system -10 feed -8 return all aero quip lines and fittings. Fully programmable msd 6010 ignition with 2 step . Interior is all still there with original Recaro seats and a nicely built 10 point cage.msd 7AL ignition with 2 step and retard function.Transmission is a race built 2 speed powerglide with a pro brake,8"5 k stall and a removable JW bell for sbc/bbc or LS,also comes with a bbf bell also from JW sfi approved.Shifter 8's a pro stick. CAR is super nice guys come have a look you won't be disappointed.
Price is $17,500 Canadian turn key
Located in Toronto Canada
check out my youtube videos.. search nasty306
