1 - 1 of 1 Posts
Selling my 85 mustang gt as a roller or complete with hurt turbo 6.0 motor, car currently doesn't run, had a knock coming from motor, needs to be gone through.
Body:
unsure of mileage, had an aftermarket speedo in it
floors are rusty, need to be replaced
6 point cage with door bars low on the floor
3" glasstek hood
3-4 year old paint job by opher (race car special he had at the time)
SOS rear wing
Suspension/rear end:
Tubular k with SBF mounts
tubular a arms
coil overs
strange struts
8.8 rear w/ 31 spline axles and mini spool
Aftermarket control arms (forgot what brand)
Greg weld wheels 15x3.5 and 15x8 with 26x11.50 Et streets
BBK caster camber plates
Quick ratio manual steering rack
Trans:
Built 400 with brake and deep pan
lokar dipstick
Hurst 1/4 stick
3200 stall
Motor :
2005 6.0 Ls truck motor
799 heads
ARP headstuds and rod bolts
Thunder TR224 cam
trickflow pushrods
Ls2 intake
90mm cable throttle body
96lb injectors
Ls9 headgaskets
Ls7 lifters
SLP oil pump
New starter
Turbo kit:
Homemade kit with flipped truck manifolds
Ebay wastegate
Ebay bov and intercooler
Ebay Gt45 turbo, 4" downpipe needs to be finished to exit fender
Misc:
Megasquirt 3 with driver box, still works with Coil on plug setup
Sumped fuel tank
Aeromotive A1000 pump with 2 filters
Fuel pressure regulator
driveshaft loop
Interior:
needs gauges, removed the non working knock off gauges and never replaced them, can include some with the deal.
has no rear seat
sn95 front seats
gutted a/c and heat
I have a dash pad for it and misc parts
This is not a show car, it's a project for someone that has some time to make it perfect. Like I said the floors are rusty but repairable, it's also missing a l/f fender extension as seen in the pictures. I am not sure what's wrong with the motor and have no time to get into it this year. I will sell either the car complete or as a rolling chassis with no motor, trans, or megasquirt. I'll leave the fuel system though.
Rolling $2,800 obo
Complete $5,500 obo
Regis
847-594-2003
1 - 1 of 1 Posts
