Car was painted 15 years ago its probably a 7.5 out of 10. The interior has just about been all replaced. New top put on last year and just got a new boot for it. All new weather stripping (not installed yet). I have 50resto 1/4 window repair kit that I havento installed yet, windows work this is just suppose to be better than factory. Also cleaned up grease and grim from the underside of the car. Put in new pilot bearing, throwout bearing and Steeda Tri-ax shifter. Call or text 618-534-2461, I can give more info or send pics. Its also on ST. Louis craigslist.
1985 Mustang GT 149xxx on body
Explorer 302
Original GT40 heads w/ 1.6 RR
Anderson N41 cam
BBK long tubes and O/R Xpipe
Spintech Super Pro Mufflers w/ LMR Tailpipes
Tremec 26 spline 5 speed w/ Steeda short thifter
New Spec Stage 1 clutch 500 miles
Ford Racing Aluminum Driveshaft
8.8 w/ 3.73s
Eibach drag springs front and back
Lakewood shocks and struts
South Side Machine upper and lower control arms
Full length sub frame connectors
Saleen replica wheels 17x8 & 17x9 with Nitto tires
Sumped factory tank with push lok hose and fittings
Holley HP 125 Fuel Pump
Price is $7200obo
