make offer on whole car, not desperate to get rid of it but willing to deal. i removed the head to see if it was the head gasket leaking, and after removing the head today saw the block was cracked on deck. not wanting to lead anyone one so thats why i didnt want to sale car complete without everyone knowing more details.
email is [email protected]
86 crank,68 hardened truck rods,stock 86 forged true flat top pistons notched for valves-still in block, but block is cracked.$100
new m66 high volume oil pump(120 miles)- $25
new comp cams 3way adjustable timing chain(120 miles)- $35
new water pump normal rotation(250 miles)- $25
Lunati # 51012 cam with specs 542i/ 560e lift and 232i/240e duration(miles unkown but in good condition)- $150
lunati hydraulic roller lifters(120 miles)- $120
ported aluminum canfield 195cc heads with 58cc combustion chamber valves are 2.02 intake and 1.6 exhaust cleaned during rebuild with lunati 73100 valve springs (good for 600 lift easily) (120 miles)-$1000
1.6 stud mounted adjustable proform roller rockers with guideplates and studs- $120
ARP head studs- $50
edelbrock victor jr intake manifold- $120
Holley 750 vacuum secondary carb (leaks alittle from powervalve but i still ran it on my car)- $125
solid motor mounts(pbm?) -$40
electric fan and factory radiator- $40
MSD 6AL ignition box- $140
accel coil- $10
brand new factory distributor with steel gear- $35
new plug wires- $10
flywheel resurfaced(120 miles)- $40
Gripforce stage 3 clutch package with six puck clutch disk pressure plate and new throw out bearing(120 miles)- $195
factory t-5 trans(not sure if 4 cyl or v8) shifts fine no grinding with b&m short throw shifter- $350
solid trans mount-$15
1 5/8 primary 2 1/2 collector bbk shorty unequal length headers uncoated. ball sockets seem out of round, didnt leak but cant guarantee they wont, could weld on v band clips- $50
flowmaster 40 series mufflers with flow tubes- $80
aftermarket clutch quadrant- $15
adjustable clutch cable- $30
new in box factory clutch cable- $25
4 lug centerline convo pros with 15x4 in the front with skinnys 15x10s in the rear with 295/50/15s decent tread except one front tire could be replaced- $600
autometer 5" monster tach with shift light- $100
car itself is a 1985 coupe, good title, rust free!
all glass is good- make offers
front bumper is good no tears that i have found- $125
rear decklid is nice- $75
back bumper is decent- $50
black carpet looks good- $75
drivers side fender is straight- $50
passenger side fender had one dent- $40
euro taillights- $50
email is [email protected] would like to deal locally or only ship smaller parts, let me know if you need other interior parts as kick panels are in good shape along with other trim pieces.
