I'm parting ways with my 85 strip/street project. I'm in Knoxville Tennessee. Need it gone quick. The good- 398 Windsor, 74 block, Afr 205 heads, shaft rockers, extrude honed dual plane intake, pro systems carb( still in box). 10 to 1 compression, comp cams roller cam healthy, but not crazy. Rollerized c4, hardened input shaft, trans brake, 3.73 gear, 31 spline axles, Eaton e locker rear end. 1 7/8 long tubes, to pro chamber. Msd ignition and distributor, 6 point roll cage, tubular k member and a arms, 70/30 front shocks, coil over adj rears, weld in torque boxes.black bullet 17x8 fronts 17x9 rears w/ drag radials. Pistol rev-lock out shifter. North race car 5 lug kit, disc brakes in rear, bolt on 4.5 inch hood, front spoiler (not mounted). Been garaged for 17 years. No rust! Big Holley fuel pump.
. the not so good, wiring needs finished for street, interior space, needs seat tracks,hasn't ran in 9 yrs, been up on jack stands since, needs battery, paint is half black half purple- fades mid door to other color, needs bigger master cylinder for manual brakes to work REALLY well. Other little things. Message me for pics and interest. Thanks
