1 - 1 of 1 Posts
This was my project car and I just don't have the $$$ to finish .....huge stack of recites will sell whole or part out ...ssm upper lower control arms, motor sport a armsl w/energy suspension bushings, motorsport c springs, 15:1 ratio rack n pinon, new inner tie rods, granatellie bump steer outer tie rod ended,Hotchkis caster camber plates, Koni adjustable shocks all four corners, all braided ss fuel lines ...s.s. brake lines, all new factory brakes inc. calipers rotors off 89 rear drums all new ...rear end out of low mileage 95 w 3.08 gears...built 302 new factory block and crank, edelbrock performer rpm intake and cam, trw pistons factory heads w all new edelbrock springs,Bronze guides Manley over size 1.94 vales, three angle valve job, billet alum. underdive pulleys, elec. Fan, bbk long tube headers, x pipe, flowmaster mufflers and tail pipes, solid motor mounts, billet alumn. accesory mounting brackets,
The body is in great shape but needs paint and a rear valance have 86 and 84 front clip have two sunroof glasses both in good shape factory sunroof ...97k miles on body and zero on all the new parts and motor,Mallory unilite dizzy...Mallory fuel pressure regulator....have subframe connectors not yet installed make offer Have reciets form most all parts and engine work....:salute:
1 - 1 of 1 Posts
