1 - 1 of 1 Posts
84 Mustang 429 big block from 71 Thunderbird, DOVE heads, 3 angle valve job, ported and polished heads, alum roller rockers, stealth alum intake, 800 Holley double pumper carb, Comp 230 Magnum cam, richmond 3.55 gears, Moser 33 spline axles, full spool, Weld draglite big n littles, MT 10.5W slicks on back, Weightjacker LCAs, subframe connectors, 8 point cage, built C6 tranny, with R servo and reverse valve body trans brake, 8" 5200 stall Coan converter with anti balloning plate, aluminum radator, aluminum water pump, electric water pump drive, dual electric fans. Has full interior and lights, can put the 3500 stall (included but not installed) back in and street/strip. Ran 11.80s in the 1/4 and 7.70s in the 1/8th with 1.63 60' times all motor. Very consistent car. $15K invested asking $9500 OBO. Trade up or down on a RZR.
1 - 1 of 1 Posts
