1 - 10 of 10 Posts
These injectors flow 86 lbs/hr at 43.5 PSI ( 3 BAR )
Need to sale my used fuel injectors, used for 360 miles and in very good condition. I needed bigger injectors. I made around 900 rwhp with these injectors. New they run $450.00-$500.00, I am asking $210.00 shipped.
FEATURES:
Genuine, reliable Siemens Injectors
Excellent response characteristics
Robust Design
Low Impedance
Specifications:
Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 86.2 lb/hr = 888 cc/min = 652.2 g/min
Connector: Bosch EV1
Spray Pattern: Pencil
Factory fitted with Viton upper and lower o-rings
Equivalent Part Numbers:
Siemens FI11405 ( 3105 )
Discussion Starter #2 (Edited)
Price lowered to $210.00 shipped. I also changed price above. Thanks
Have not sold these yet! Only 360 miles on these things.
These were in my 65 Cobra replica and at 850-900rwhp they are at there safe limit so I added 120 lb/hr injectors now I should have lots of room to grow!!! Thanks here is a picture of the car. -------------------
Not to hijack your thread, but what are you running EFI wise with that combo and how is the drivability with it?
I am doing a similar build - but running E85.
Mighty Mouse, I am running Big stuff 3 fuel management system the the drivability is great, even big injectors. Bpohlman13, They will fit the car but I think you will need the EV1-EV6 plug adapters.
Injectors sold this morning. Thanks
1 - 10 of 10 Posts
