Hi all, are 66 Ib injectors too big for a stock block, stock cam, gt-40 head/intake 306 w/ a 68mm @ 6 psi? I was worried the idle may be too rich. Tuning will be with Holley HP efi if that matters. Thanks!
Absolutely not. I wouldn’t recommend anything smaller than 60’s personally with anything under boost. You can tune everything with that Holley, so don’t worry
Thanks for the reply. It just seemed back in the day people ran 42Ib injectors with a set up like this, but that was with SCT chips for the tune.
They also probably ran a FMU too. Don’t do that. Run a big enough injector and fuel pump.
