Very strange problem with trans after a rebuild by trans shop. I later found out, they were not reputable. Can't take it back again, they won't work any more on it and we are in litigation.
Trans originally had overheating and blown OD gears. I think the shop took the good parts remaining, plus unknown parts, and built a good unit. Except, here is the problem:
Immediately after a ECM KAM (keep alive memory) clear, the trans shifts like butter. Runs very nicely. Everything works fine. However it proceeds to learn a harsh 2-3 shift, which seem to get worse. Throws no codes and has no other issues. After 300+ miles the 2-3 shift becomes quite harsh and unacceptable. Reset the ECM again, and this process is repeated.
Your thoughts are appreciated! Worried I need to completely replace this trans.
There is a very specific procedure for the trans shift strategy to be learned. If that was not performed after the rebuild, then the trans will not shift correctly.
