1 - 20 of 28 Posts
looks like i will have some decent $$$ to play with soon, with tax time around the corner, i am having a hard time deciding on a LSX 6.0 with L92 heads or a 545 ci BBF , i want to run 9.90 or faster
i would think it would be easier and cheaper with the LSx.
smaller package, a lot lighter, make the same power with the same ease.
just my opinion.
just my opinion.
im open to all opinions, i have no experience with the lsx motors, i would like to learn, on the other end i know a 545 with good heads will make 700+ hp, on the down side a good set of heads to feed a 545 motor cost about 3k, i will only have about that to spend on the car
a built LSx with some spray can make that too, on stock GM heads.
i think i could build a LSX motor for what i have to spend and headers
it would be pretty kick ass.
i would be willing to bet that a 550-600 HP lsx with go just as fast as a 700hp big block just because of the weight diff.
LSx would be a great idea, very stout engine with tried and true potential. Can't beat the new technology of the LSx either. Just keep it in the same chassis as the company that made the motor and it will be kick ass.
i do not want to use nitrous,i want a fast bracket car, found several 6.0 motors , for 500.00 there is one on CL that came from a esclade that already has L92 heads , for 500.00
the only problem with your theory is that its actually torque that matters :evil:
+1
thats a deal, BUY IT, the esclades have aluminum blocks too, even lighter.
Discussion Starter #13
Since a complete aluminum headed 545 BBF can be built for less than $6000 complete, I think the choice is obvious for a 9.90 car. Add minitubes, UPR suspension, adjustable coil overs, and some 12" slicks and you'll have a low 9 second all motor car with a less than $6000 motor.
Do more research and see just how cheap the BBF parts are.
I'd like to see this 545 for under 6k, care to make a parts list with prices?
6.0L LS motor with 2 small turbos and about 8psi will feel like
a 600" big block.
Quick summary:
Complete heads from Jegs: $2100
Rotating assembly w/rings and bearings: $1500
Carb: $800
Intake: $300
Headers: $400
Cam/lifters/push rods: $450
This is a slight over estimation in prices but covers the most expensive stuff.
Obviously buying used saves a lot of money.
Quick summary:
Carb: $800
Intake: $300
Headers: $400
Thats 5500 bucks before machine work, and you dont have a block rockers, valve covers, timing chain, balancer etc. That would be an 8-10k dollar build easy. There is 6k just in parts.
1 - 20 of 28 Posts
