authorized corral.net advertisers
Wanted to share with the Corral members a shot of our billet chain guide system, we have addressed every issue within the timing cover of the 5.0 Coyote engines, the MMR Pro kit includes a Billet crankshaft gear to prevent the common cracking at the keyway, Billet oil pump gears to prevent the common powdered metal oil pump gear failures, Billet chain guides to replace the cheap plastic guides that cause unwanted timing variations due to flex, secondary tensioner bracket to flip driver tensioner upside down to prevent tensioning chain on the wrong side, SHD secondary chains to replace the weak factory chains that commonly break with aftermarket cams and springs, Billet steel secondary chain guides to prevent the softening common the the factory plastic when used with race fuels, camshaft phaser deletes to reduce almost 3 lbs of rotating weight and allow for cam adjustability and lastly billet primary hydraulic tensioners to prevent leaking between the cylinder heads and tensioners. As a side note we also offer similar kits for the 4.6 DOHC and SOHC.
