1 - 18 of 18 Posts
Would anyone have a round about idea what a 446 cid windsor would make power wise?
Dart SHP 4 bolt mains block
4.125 bore
4.170 crankshaft
6.250 eagle h-beam rods
Ross 14:1 compression custom pistons
AFR 220 Renegade Heads 58cc
282/292 @ 50 duration 725 Lift 114 Lobe sep
Super victor intake
MSD Crank trigger and ignition
1100 cfm prosystems dominator
I actually have a desktop dyno program, I can run it through just for ####s.
E85 combo?
If you can't make over 850 N/A you are doing it wrong
With AFR 220's and a Super Vic? Not happening.
Sure it can. 15 years ago I made 620 HP N/A with a 347 Victor Jr heads and a Victor Jr Intake with a smaller nitrous cam with less compression. With an extra 100 cid and extra compression, better heads, intake and cam it is a walk in the park.
With 13:1 454 Windsor, afr 225, super victor we made 707 at high 6k low 7k, which is right where the math said it would make. Also set up for spray.
I would guess yours will make a few more. How about 720?
Discussion Starter #16
Just received my custom pistons from Ross and calculated my compression ratio, it should be somewhere around 14.64:1, plan on running a fogger with 250 shot with nitrous 120 fuel, my goal is 5.50's or better in the 1/8 mile, any opinions?
Would need to know weight of car, trans and gearing and tire size/type
1 - 18 of 18 Posts
