1 - 13 of 13 Posts
anywhere from 13's to 8's... depends how hard you are willing to push one
I've been 9.75 at 143 in my 86 coupe. 408w Victor Jr unported heads, vic jr intake and a cheapie off-the-shelf cam of unknown spec. Yes hydraulic roller. I bought the cam used. Was a solid roller, but lost a lifter and damaged the cam, and found a guy selling a Hyd roller cam and lifters of unknown spec locally. I just stuck it in and it runs exactly the same as the solid roller did. Max RPM at finish line is 6900 at the 1/4 mile. Usually runs 1/8 mile and geared differently. 60' 1.36 on the typical 1/8 mile setup (with 4.86 geared 9"). Car is currently at my brother's house. He drives it mostly. Typically in this heat, it runs in the 9.80-9.83 range. That said, the engine is going to come out to go into a Maverick that my dad bought years ago; and the coupe will have a 347" back in it, which last time out, went 9.99/135.
N/A? No nitrous?
11.0 at 127 with my foxbody coupe and TKO600 transmission. All motor
  • Like
Reactions: Alexender
Fastest I've been is 11.95 at 114.75, Astro A5, NA. Unfortunately I am playing at a much different altitude than most of you. Typical track DA where I run is usually in the 8500-9500' range.
I did just build a new exhaust system for my car and had it re-dynoed (I picked up 28 hp and 29 torque). Hopefully this will put me in the solid 11's.
Apparently my new exhaust build did make a difference. I ran a personal best tonight of 11.77 at 117.4 with a 7400' DA.
Nice. You need to come out here and run in some good air. A bad day here the DA is 3,500 feet lol. The best air I have ever seen was -500 below sea level. Talk about mine shaft conditions.
If I am ever out your way I'll hit you up. I would love to be able to run on your worst day, my car would be a different animal! I was thinking about trying to go to one of the tracks in Kansas or the like but I am guessing I would enter the realm of a whole bunch more safety equipment.
should come to world cup in november... we see -3500 at times
1 - 13 of 13 Posts
