1 - 8 of 8 Posts
Located in Southeast Iowa
  • 4.6 Romeo Cast short block standard bore
  • Romeo steel 6 bolt crank
  • Boss Roadrunner Forged Rods
  • Mahle -16 dish forged pistons
  • Romeo PI Heads
  • CMS stg 2.5 Cams and springs
  • Eddy Intake
  • Eddy Rails / -8 feed -6 return
  • Magnafuel Boost reference regulator
  • Siemens Deka 80lb injectors
  • 6061 Plenum
  • Trickflow 75mm throttle body
  • MSD Coil Pack
  • Ford Racing Plug Wires
This will come with the alternator too
Engine has made 600whp. Runs great, no smoke or blow by whatsoever. Still in the car and running.
SOLD - https://forums.corral.net/forums/power-adders/2495742-4-6-2v-turbo-kit.html
  • Like
Reactions: jamessr23
Discussion Starter #2
Bump
Most recent video of the engine running this past weekend. Putting the car away for winter, AFRS are a little rich due to flushing the fuel system from e85 to pump gas for storage.
Price drop $2200
What do you think this makes naturally aspirated? Wish you were closer! Thanks
I really dont know, a stock healthy bolton 2v makes what around 250-260rwhp? Id say with the bump in compression and cams it may be close to 300. NA .... The cams currently in it are blower cams though.
Bump
SOLD
1 - 8 of 8 Posts
