1 - 11 of 11 Posts
i have a 1992 LX and just did a 3g alternator upgrade. Wanting to make sure I wired it correctly. I am seeing contradictory wiring diagrams.
I followed the following install to wire my 3g alternator: https://www.stangnet.com/mustang-forums/threads/3g-alternator-install-a-how-to.646825/#post6673702
In this install, the (2) black/orange wires in the OEM harness are NOT used.
However, in other installs, the (2) black/orange wires are also installed with ring terminals on the stud along with the 4GA power feed.
Here's an example: FORDMUSCLE webmagazine: PA Performance 3G Alternator Upgrage
Which one is correct?? Thanks.
setup it up to use the two wires, but don't use them yet, just tape the out of the way
start it up, and check charging voltage
report what you get.
  • Like
Reactions: RTW0223
x2 what Indy said. When I wired mine I tucked the two black wires out of the way and only used the new 4ga wire. All is well.
Apologize for the delay... anywho... been starting and running OK with the (2) black/orange wires NOT connected... just the 4ga wire. It doesn't even make sense to have the alternator connected to two power sources... Don't know why some companies are advertising to leave both black/orange wires connected. Voltage reads good... above 14V. Now onto fixing the other problems with the car... LOL
Did you have to do anything other than disconnect the orange/black wires at the alternator and the starter solenoid? I've read on some threads that a voltage wire is also tied in to the orange/black wires at the starter solenoid.
Edited to add: I have seen that the black/orange wire shares the fusable link with the yellow wire at the starter solenoid. Where does the yellow wire go? I'm trying to figure out if I can remove the orange black wires from the car (and starter solenoid) without causing problems.
Last question, where does the white/black striped wire at the alternator go? IE, it is in the wire loom and following the orange/black wire. Where does it go on the opposite side of the alternator?
Thanks,
Chris
BK/o has no fuse link
yellow wire goes to 'a' of reg, it has fuse link 18gauge
w/bk jumps at the reg attaches to the 's' of both the rectifier and regulator
this is from 89 evtm
I did find a pretty decent picture showing all wires.
could a single "jumper" be used to replace the factory Yellow Voltage regulator Sense switch wire?
I'm asking If I could use a single 14 gauge wire from the 3G alternator post and run it to the 3G's regulator plug's yellow wire? If so, I THINK you could remove the orange/black wires and yellow wire at the solenoid completely.
fused yellow, as close to the battery as possible
that is how you do it
  • Like
Reactions: 351
See p.12A (p.16 of pdf)
https://drive.google.com/open?id=1on5czXKmpETzxUggWTGtoUuVkJT2UUxN
  • Like
Reactions: 351
1 - 11 of 11 Posts
