*****Kinda need an answer ASAP*****
I am in the process of installing a 3G alternator into my 87 Notch. It had the original 2G. I cut the wires for the output plug (2 black with orange stripes and 1 white wire with black stripe). I pulled back the plastic loom and tape. The 2 black wires connected to another (1) black with orange stripe wire which was the same size wire. They were half assed joined at the factory. The three wires came apart. My question is can I just use one of the black wires with the eyelet connector onto the alternator. Or do I somehow have to connect the 3 wires back together again? Which looks to be a pain in the ass.
Are you using dedicated b wire as well?
Not sure what you mean by dedicated b wire? Also I forgot to include that I was using the 95 amp alternator.
the charging wire from the alt b post to the distribution
