Hey Guys, what system are you guys using? I have a breather on both valve covers and getting tired of oil drip coming out of the breathers and making a mess.
My catch can seems to gather quite a bit of oily water when I drain it.you need to remove water from the crankcase
a simple vent does NOT do that
if you do not have a pcv system, you have a vent
you are capturing the excess, what is spilling over into the can, not all of it.My catch can seems to gather quite a bit of oily water when I drain it.
Ha, ya, I bet those products of combustion are great for internals!you are capturing the excess, what is spilling over into the can, not all of it.My catch can seems to gather quite a bit of oily water when I drain it.
that water and other by products of combustion make nice acids that aid in bearing lubrication
for a strict race car this aint a problem as oil changes are frequent
for a street or cruising car, even worse, expect a nice shortened life from that engine.
and if you think its paranoia....that is fine, your money.
its not the byproducts themselvesHa, ya, I bet those products of combustion are great for internals!
I guess I’ll have to remedy this by continuing to change my oil very frequently. Maybe I get away with it because I change my oil after the few track days I attend. I don’t think I go more than 500-700 miles between changes. Overkill probably, but I don’t drive it more than 1,000 miles a summer anyways.
It makes sense. Vacuum pump system may be in my future. Something that sucks it out rather than just vent
and let fresh air into the crankcase
sort ofWhat’s the point of fresh sir? Just to help flush everything? Fresh air in, dirty stuff out, type of deal?
