1 - 10 of 10 Posts
Well today we hit the dyno didn't get the numbers we were expecting
Here's the combo
363 dart block
Victor jr heads
Trickflow r carb intake
850 qf blow through
V1 with 918 motor sports impeller at 5 psi
Comp cam blower cam
-RPM Range: 2000 to 6000
-Valve Timing: 0.006
-Lobe separation (degrees): 114
-Intake Centerline (degrees): 110
-Valve Lash: Hydraulic
-Duration: Intake 276/ Exhaust 280
tko 600 McLeod clutch
382rwhp is the v1 choking it out? Any input is appreciated
Try it without the blower? Those should be NA numbers at the very least!
Something is seriously wrong I think. Not much help but keep us posted. Good luck
Sent from my SM-G920V using Tapatalk
Yea that's my thoughts we didn't do a n/a pull we ran outta time was just looking for some opinions before we pull this blower off
I wouldn't pull it off completely, just take off the belt and discharge tube.
Found a hurt impeller it was barely making 5psi I would think the motor should almost make that power
You should be making 650+.....but not at 5psi. What size crank and blower pulley. Is that a S or T trim? You wont make any power with that blower until you make at least 15psi
You definitely need more boost for 1 thing. What is ur current pulley setup?? My mild dart 331 supercharged on a mustang dyno made around 615hp at the tire with a tko tranny. And made 570's at the tire when I switched to a built TH400. Here are the specs below...
Dart shp block
-Eagle 331 rotating assembly, steel crank, h-beam rods
-AFR 165cc heads with comp cam spring kit upgrade
-1.6 roller rockers
-Tfs upper and lower track heat intake
-Comp cam .580int. .588exh. @.50 236int 248exh
-1 3/4" longtubes, 3 inch exhaust, 10 series flowmasters dumped at the rear axle
-Vortech older v2 s-trim w/powerpipe making 12-13lbs with a 3.15" upper and 8" lower crank pulley
-Vortech after cooler setup
-Coan TH400 tranny with 3500 stall
-Built 8.8 with strange 33 spline axles, 3:73 gear, spool and c clip eliminators, girdle cover.
-aeromotive dual phantom in the tank fuel system running on pump e85
-holley efi ecm
1 - 10 of 10 Posts
